Vacuum canister to Electronic advancement switch
Old Dec 24, 2002 | 03:55 PM
CHEVYTOWN's Avatar
Sup hometowns...
I have a Chevy 63C10 with a 250cid powered by a 560cfm 2 barrel TBI using the 7747.
Is it possible to go Electronic for advancement of timing on the dizzy from the current set-up I have now, which is the vacuum canister. It is being utilized to take care of the advancement for the timing.
Is there a post someone can lead me too...I tried a search but got nowhere near my deal...
CHEVYTOWN
Old Dec 24, 2002 | 11:10 PM
Brent's Avatar
In a word, yes.
The 747 has timing control built in.
Now, I don't know what the deal is with the V6 vs L6. Some GM 6's are odd fire and some are even fire. Maybe the only difference is the dizzy cap. I donno.
Best thing, as far as I can see, is for you to contact the folks that supplied your kit.
Old Dec 25, 2002 | 03:36 AM
CHEVYTOWN's Avatar
Thanks for your response hometown.
That's a 10-4 on contacting Howell.
I prefer letting the ECM do the advancement. (On a side note, I just installed a 2004R, can the trans be wired to the ECM so that I don't have to use the TV cable? The only thing is, the electronics are inside, built inside the casing...)
I have Howell's Service manual. I'll study that and see if there is any info in dem pages...
Muchas Gracias...
Old Dec 25, 2002 | 08:56 AM
Brent's Avatar
You will have to use the TV cable. Make sure you have the proper geometry for the cable pull at the throttle body or you could shorten the trannys life. If you search the www there are some diagrams with the measurements.
The only thing the ECM controls in those trans is the converter lockup.
Old Dec 25, 2002 | 11:04 AM
CHEVYTOWN's Avatar
The TV cable is in an akward geometry because of the L6's nature. I hope it doesn't burn my trans...
Thanks for your help Brent...
Ricardo
www.fungusworks.com/TheShow/index.html
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
db057
Sep 4, 2015 07:57 AM
86IROC112
Aug 17, 2015 02:00 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
