Non drop aircleaner
Old Dec 28, 2002 | 10:40 AM
Firebird sweden's Avatar
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
Non drop aircleaner
Hallo!
Does anybody have a ordernumber for a good non drop aircleaner
14X3" to my 305 tbi.
Thanks.
Old Dec 28, 2002 | 08:32 PM
MY-92-RS's Avatar
Car: 92 CAMARO RALLY SPORT
Engine: 383 sbc w/250 shot of nitrous
Transmission: AMERICAN POWERTRAIN- EXTREME TKX
Axle/Gears: STRANGE ENG. 12 BOLT 3:90 SPOOL
this should do
K&N Air Cleaners
Product images may differ from actual product appearance.
When it was first developed in 1962, the K&N Filtercharger® was a true design breakthrough in air filtration technology.
Today, it still is. Because K&N's Filtercharger® can actually double air flow, which, in turn, adds up to 15 extra horsepower.
The secret lies in the K&N Filtercharger®'s unique design. Conventional filters use paper or foam material permeated with millions of tiny, irregular passages, that screen dirt particles out of the air. Because the dirt particles are trapped inside the passages, they eventually clog; and when this occurs, airflow restriction increases dramatically. With the Filtercharger®, a special cotton fabric is sandwiched between the pleated aluminum screen wires. The pleated design provides five times more filtering surface over the element circumference. The cotton/screen wire filter media is then saturated with a formulated air filter oil. Acting like a fluid curtain, this oil attracts particles of dirt and debris which build up on the outside of the filter. This buildup of dirt particles suspended in oil creates more and more irregular passages that actually create an additional filtering barrier with use. In most cases, up to 1/8'' of dust can cover a Filtercharger® before performance is significantly affected. On a street driven vehicle, a Filtercharger® can last up to 50,000 miles before service is required. Then, because it's made of reusable materials, you can just clean it, apply fresh K&N Filter Oil and re-install. Of course, K&N has developed biodegradable cleaning products designed to effectively clean the filter without harming the environment through the absence of fluorocarbons.
More air flow, increased horsepower, long lasting performance _ even after 35 years, the K&N Filtercharger® is still on the cutting edge of air filtration technology.
14'' Air Cleaners:
Flat base, with 1-1/2'' offset base to clear HEI distributors.
599-60-1400 Neck: 5-1/8''
Element Height: 2-5/16'' $85.99
599-60-1410 Neck: 5-1/8''
Element Height: 4'' $100.99
599-60-1420 Neck: 5-1/8''
Element Height: 5'' $104.99
14'' Air Cleaners:
Raises element 9/16'' above carburetor flange.
599-60-1260 Neck: 5-1/8''
Element Height: 4'' $85.99
599-60-1264 Neck: 5-1/8''
Element Height: 3'' $82.99
599-60-1270 Neck: 5-1/8''
Element Height: 5'' $87.99
14'' Replacement Element Only
599-E-3740 Element Height: 2-1/4'' $43.99
599-E-3742 Element Height: 2-13/16'' $56.99
599-E-3743 Element Height: 3'' $51.99
599-E-3750 Element Height: 4'' $48.99
599-E-3760 Element Height: 5'' $52.99
599-E-3770 Element Height: 6'' $55.99
14'' Triangle Air Cleaner - View!
599-60-1470 Neck: 5-1/8''
©2002 Jeg's High Performance. All rights reserved. | Privacy Policy
Old Dec 29, 2002 | 03:41 AM
Engine: 383 HSR TPI
Axle/Gears: 4.10
OK!
Thanks a lot!
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
