what crate motor
Old Jan 25, 2003 | 05:52 PM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
what crate motor
i am looking at geting a new motor for my truck. the one in it has 211,000 on it and is is starting to realy suck down fuel and use oil. i would like to be able to throw the new motor in and roll not have to burn chips and such as i do not have the skillz or the time to lern the motor needs to be able to be swaped in, in one week end so i can get to work on monday. what would be a good choice i was looking at the goodwrench but it would realy suck if i did all this work then the thing was more of a dog after the swap. so what do you guys think i should get. i have a lo5 with a holley tbi in it now.
Old Jan 25, 2003 | 08:28 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
If you dont want to touch it and youy jsut want to put the motor in and be done with it, id just go get another crate LO5. Its the same motor that you already have and it wont require any tuning. Pretty much any other combo that makes something resembling power will require some tuning and probably a chip. Stay away from the "goodwrench 350", which is waht i assume your referrring to. Not only does it make less power then the LO5, have a flat tappet cam, and leak oil like a seive, but youll need to get some more parts to accomodate the older crank and head style.
Old Jan 29, 2003 | 06:03 PM
Tallboy's Avatar
http://www.chevy-gas-diesel-engines....ngine-249.html
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
italiano67
Dec 11, 2016 09:21 AM
Steve78LT
Feb 24, 2016 12:15 AM
masonta
Aug 31, 2015 10:14 PM
