Does a Holley Open Element Fit?
Old Jan 26, 2003 | 03:23 PM
LowStyleII's Avatar
Car: 1998 Camaro
Engine: V-6 200 HP
Ok I am thinking about going downtown and picking up the Holley 14"X3" Open Element. The guys says its for the Holley carb. Well that makes sense. Does anyone else have this on thier TBI? What about the tbi spacers? Keep em or leave em? I will get the 14" K&N filter later since all I have is the 12" now. Maybe I can find a cheap aftermarket one to replace the stock one it was packaged with until then. This is the last open element question for a long time.
Old Jan 27, 2003 | 10:20 AM
LowStyleII's Avatar
Car: 1998 Camaro
Engine: V-6 200 HP
Anyone? I'm trying to do this as soon as possible.
Old Jan 27, 2003 | 12:16 PM
Rockin88305's Avatar
On my 88 tbi camaro i have an edelbrock 14x3 open element filter. It fit perfectly. The only thing is you must drill a 3/8 pipe thread hole in the base to mount your sensor back into it. As far as the tbi spacer there is almost no hope of that fitting under your hood because of clearance problems. The top of my air cleaner now leaves an imprint in the insulation under the hood without the spacer. But i Know a few people who have used them on there pickups and are really happy with the results. If it fits it would probably be worth it.
Chris
Old Jan 27, 2003 | 09:55 PM
deadtrend1's Avatar
if you use a non-drop base open element.. then the spacer ring can come off the throttle body.
If you use a drop-base open element .. then the spacer ring will need to stay in. Why? because if you dont, the air cleaner will rest on your cables and distributor and be crooked.
Id make every attept possible of getting that spacer off (IE. getting the non-drop base) because its kinda little dumb GM idea. It blocks a lot of air getting into the motor.
Old Jan 27, 2003 | 10:29 PM
LowStyleII's Avatar
Car: 1998 Camaro
Engine: V-6 200 HP
Well I'm done and it worked. Its just I can't post a pic and its only like 853KB so I dont know how everyone else does it and I cant still. I't didnt throw any codes and I got rid of the TBI spacer.
Frozer!!!
Jan 19, 2024 04:55 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
theurge
Aug 21, 2015 12:46 PM
wruiz
Aug 13, 2015 09:07 PM
