Fault codes, and now what?
Old Feb 2, 2003 | 08:32 PM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
Hey, the camaro (88 Sport Coupe, 305 TBI) has been acting up lately, its been idling really rough, and sluggish to drive. Once the engine gets up to 2500, 3000, it just takes off. I pulled the codes from the computer, and came up with a 33 and a 45
33. High voltage (low vacuum) at mass air flow sensor (or MAP sensor
45. Oxygen sensor rich
Now I need to know exactly WHAT the problem is, now that I have the diagnosis. Any help and suggestions as to what the next step should be would be appreciated.
Dave
Old Feb 3, 2003 | 12:42 AM
TBIfly's Avatar
33. check for engine mis-fire...are all your vacuum lines connected properly? all your wires in tact and connected.
44. Lean exhaust.....check your O2 sensor....change it.
this is all the help i can give.
http://wrenchman.freeservers.com/fordsux/gm.htm
the site is a listing of all the codes in a bit more detail, not much
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
