smog pump bracket
Old Feb 6, 2003 | 11:54 PM
25THRSS's Avatar
smog pump bracket
hey guys this is my first post on this board, anyways i have a 92 camaro rs and i wanna remove my smog pump to clean the engine up a little. I was wondering if there is some kind of bracket that i can buy for my ac and belt tentioner that doesnt have the hole for the smog pump. I dont wanna remove my smog pump and just have a gaping hole where it used to be and it looks like somethings missing. I know i can buy a smog pump delete pulley, but i wanna remove as much unneeded things as i can. Just to help u out with what i'm saying, i think ZRATED has one called a tx smog pump delete option, but i'm not sure, thanks guy, sorry for the confusion.
Old Feb 7, 2003 | 12:01 AM
deadtrend1's Avatar
Rip it out .. toss it into a dark corner and forget about it!
It looks better without it, you dont see a large gaping hole .. and theres more room and less hose to work around. Just reroute the belt.
Heres mine removed ...
and
Old Feb 7, 2003 | 12:06 AM
25THRSS's Avatar
see in that pictute where the smog pump used to bolt up to. Is there any type of bracket i can buy that doesnt even have the provisions for a smog pump? thanks for the pictures man, I'm just tryin to make my engine look the cleanest i can. I kinda think that just removing it makes it look like somethings missing, not trying to disrespect or anything, u got an awesome car. thanks
Old Feb 10, 2003 | 10:45 AM
PhilM's Avatar
Car: Accepting applications...
I doubt there is a bracket. GM sells the bracket/pulley set up as an a package fors treet rods and such, and they use the same bracket with an idler pulley in place of the pump. Deadtrend is absolutely correct, I did mine the same way.
Just lose it and forget it...
evilstuie
Jan 9, 2020 08:29 PM
italiano67
Dec 11, 2016 09:21 AM
Genopsyde
Nov 11, 2015 10:46 PM
toronto formula
Nov 10, 2015 06:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
