knock sensor and harmonic dampner
Old Feb 7, 2003 | 02:47 PM
rad8tion's Avatar
Car: 92 RS Convertable
Engine: RAMJET 350
Transmission: G-FORCE T-5
two quick questions:
1.which side of the block does the knock sensor go on?
2. can I use the 6 3/4 inch balancer that came off my 305 on my '88 LO5 350 block or do I need an 8" one like the one that came off the 350?
thanks
ryan
Old Feb 7, 2003 | 02:58 PM
vjo90RS8's Avatar
Car: 2002 Z28
the knock sensor goes on the passenger side of the block
well, according to Summit racings 6 3/4" balancer, it can be used 262-400ci internally balanced small blocks. So im guessing that you should be able to reuse it, but this is just a guess.
Old Feb 7, 2003 | 03:32 PM
steve8586iroc's Avatar
If I'm not mistaking I think the 305 balancer is a light weight one not the one you would find on a 350. I would just use the one that came on the 350 if it is in good shape. If not get a new one from Summit or Jegs.
Steve
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
