So I'm putting in new spark wires...
Old Feb 8, 2003 | 05:53 PM
CrispyClutch's Avatar
I'm pulling out the 1st spark wire...I dont know how old the spark wires are,but they were OLD! Anyway I'm right away noticing a horrible header burn on it...I flex the wire a little bit and it just disindigrated in my hand!
Turns out the old wires were all burned and brittle...I just put some cheap $18 accel 7mm's in...actually I have got 2 of them so far on before the sun went down. Anyway I think it will be interesting to see if the car acts any different after getting new wires.
Also,has anyone used Accel wires before? I guess I have to buy some sort of a crimping tool to properly seat the connection to the distributor cap...pain in the ***...
Old Feb 8, 2003 | 09:18 PM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
If they were burned good enough they'll ground to the headers and you'll notice a great difference with new wires. Make sure you zip tie or use wire looms to get those wires away from the header tubes it only takes a few hrs or so to burn through a touching wire(maybe less).
edit: I just bought some 8mm accel wires, you can probably get away with good plier skills or buy a cripper (~$8-12) I don't remember the price.
Old Feb 9, 2003 | 01:35 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
I ran the Accel 8mm's too, they were OK. I have a set of Moroso's that are going on over spring break.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
g.l.mos
Aug 22, 2015 12:02 AM
transamgta1Khp
Aug 17, 2015 12:18 PM
