knock counts
Old Feb 17, 2003 | 06:08 PM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
knock counts
im using winaldl and the knock counts just count up quick when i rev it, but when in gear it only goes up by one or two points. y does it count so high when out of gear and reving. when in gear i can floor it to 5 grand and it wont have another count till i let off the throttle. so it knocks on decel. how can i fix this. my timings at 9° so ill put it to 6-7 and see if it still knocks.
Old Feb 19, 2003 | 06:54 AM
JPrevost's Avatar
Car: 91 Red Sled
Don't worry about a few knock counts. They're normal. If you don't see ANY then there is a problem or you've disabled the ESC/knock sensor diagnostic code from within the eprom.
Don't retard the timing unless you notice a performance difference. I would only make timing adjustments for WOT when I had a way to measure performance, winaldl isn't good enough. Lockers, wideband, dyno, or the track. Anything else and it's just going to waste your time.
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
spartanreaper
Sep 25, 2015 07:22 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
