need a supercharger
Old Feb 17, 2003 | 06:27 PM
400hp25th's Avatar
need a supercharger
looking for more hrspower summit said they do not make a supercharger for the 92 305 anyone know of a different story.
Old Feb 17, 2003 | 06:49 PM
NJ SPEEDER's Avatar
holley sells the b&m charger line. they are called power chargers and the small block version says 144 i believe. it is a roots style blower that will not fit below the stock hood. on a 350 it is supposed to be pullied to supply 6-8 psi i believe which woudl be around 9 or 10psi on a 305. this woudl be a good boost level for a motor that is only 9.2:1 stock and woudl give you well over 100 additional ft/lbs through most of the power band.
basically any blower that is for a 350 tbi truck can be adapted to work on your car. teh roots style blower is nice because it comes with everything needed for instalation except teh bigger hood you will need
later
tim
Old Feb 17, 2003 | 09:03 PM
JR305's Avatar
It gets discussed on the Power Adder board a lot, just run a search there. For a centrifugal supercharger I think I remember reading that you can generally get the TPI kit with a carb bonnet and some custom pluming to make it work.
Old Feb 17, 2003 | 09:19 PM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
I found it a tbi super charger adapter heres the link and bid with your head up HIIIIIIIIIIIIIIIII
http://cgi.ebay.com/ebaymotors/ws/eB...category=33741
Old Feb 18, 2003 | 06:18 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
with a little work you could probably get the cheaper wieand 142 to work, it is a generic roots for a carb, i would guess that with some work to space the pullys correctly , and an adaptor for the TB, that this blower woudl work , and it si 1500 bones vs the 3k for a 144 for TBI.
InfinityShade
Feb 21, 2016 01:29 PM
toronto formula
Nov 10, 2015 06:17 AM
-=Z28=-
Sep 24, 2015 10:21 AM
anesthes
Aug 24, 2015 08:32 AM
PestilenceIV
Aug 20, 2015 03:32 PM
