question for those running a 350
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Does anybody have part numbers for the esc module and knock sensor? I'm not sure if I'm supposed to use ones made for the 350 tbi caprice, or an L98. The ones made for a 350 will work with a 383, right? Everything else should transfer over, right? I think those are the only two things that must be changed, but let me know if I'm forgeting something. Thank you, Roy
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
350 Knock Sensor: #10456288
350 ESC Module: #16128261
(these are the ones GM recommends for the ZZ3 Fbody swap)
-Rich-
-Rich-
