MSD Retard Feature Questions
Old Feb 20, 2003 | 08:57 PM
mylittlemule's Avatar
Car: 87 Wrangler
Engine: 355 TBI
The Mule never starts quickly unless it is already warm. Does my MSD 6al retard the timing at all while starting? I have heard that if you have your timing advanced then the spark comes later in the combustion cycle, making it harder to start. If this is the case, where are people running there tiing at?
Old Feb 20, 2003 | 09:14 PM
NJ SPEEDER's Avatar
with advanced timing the spark comes earlier. there is no real need to worry about timing retard at start up unless you are running a very big cam that calls for a ton of advance at idle.
most stock cars run best around +6 to +8
later
tim
Old Feb 20, 2003 | 11:11 PM
Car: 87 Wrangler
Engine: 355 TBI
Thanks Nj Speeder. 6- 8 degrees was were I have been running but, I always thought was a bit high for a TBI cam.
Cool man
Old Feb 21, 2003 | 08:42 AM
steve8586iroc's Avatar
The reason it takes a couple of seconds to start when cold is that the fuel pump has to prime the injectors. All tbi's seem to be this way. Probably due to the presure regulator leakind down over time.
Steve
beastin91rs
Oct 9, 2015 07:38 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
midias
Aug 15, 2015 05:07 PM
tartagliaz28
Aug 15, 2015 10:59 AM
