fuel leak. how do I fix?
Old Feb 26, 2003 | 04:54 PM
Dragons91RS's Avatar
Car: 91 Camaro RS
Engine: 305 LO3
Transmission: 700-R4
Ive got a fuel leak where one of the fuel lines goes into the TB. Ive included a pic. how do I go about fixing this?
Old Feb 26, 2003 | 05:05 PM
PaulD's Avatar
Car: 93 9C1 Caprice
Engine: 5.7
Axle/Gears: 3:42
Hold the larger hex stationary with an appropriate wrench. Loosen the smaller hex nut and there is an O-ring in there. If you're lucky and you haven't bent the line so the O-ring can't seal, then inspect the o-ring and make sure there are no nicks or gouges in it. If it isn't perfect, replace it. Autozone has a cheap rebuild/gasket set for TBI.
I'm presuming that both hex fittings are already tight. Loosen the smaller one before you tighten the larger one, then tighten the smaller one.
And for ***'s sake, get rid of that collar around the TBI!
steve8586iroc's Avatar
There is a nylon washer that seals the fuel line to the tb, get some new ones and replace them both. That should take care of the leak.
Steve
Old Feb 26, 2003 | 07:25 PM
NJ SPEEDER's Avatar
steve is right. takje a 3/4 inch wrench and put it on the lug that is in the tb and a 16mm wrench and put it on teh fuel line to loosen them. there are actually 2 seals in play there. one is a small rubber ring on teh fuel line and the other is a teflon washer inside the lug taht goes into teh injector tower. when you seperate teh fuel line you will be able to see the rubber ring, it is a redishorange color usually, if it looks good jsut take the lug out of the injector pod with the 3/4 wrench you already have out and make sure tha tis good too.
your parts store shoudl have both in stock adn they are only a few cents each, so it si no big deal to fix.
later
tim
Old Feb 26, 2003 | 08:16 PM
Car: 91 Camaro RS
Engine: 305 LO3
Thanx for the help you all! I'll get the new seals friday morning, hopefully I wont go up in flames between now and then
BTW should I change the seals on both lines going into the TB now just to be safe?
Old Feb 26, 2003 | 10:07 PM
camaro89rs355's Avatar
Car: 89 Camaro RS
Engine: 355 TBI
Yes you should do both of them at the same time and when you get that fixed get you some tb cleaner and clean up the tb. That is one dirty tb.
Old Feb 27, 2003 | 08:35 PM
89 4Mula 350 Tbi's Avatar
If money isnt tight while your there replacing those two seals just buy the tbi rebuild kit its like 25-35 dollars its worth it imo if your alreayd taking the injector pod off.
mustangman65_79
Apr 14, 2017 05:37 PM
theshackle
Mar 5, 2017 06:37 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
86IROC112
Aug 17, 2015 02:00 PM
bamaboy0323
Aug 15, 2015 07:20 AM
