Power & 1/4 mile predictions
Old Feb 28, 2003 | 11:15 PM
vwdave's Avatar
Gimme a basic idea on what I should expect with this. The 1/4 time is not going to be tested anytime soon, but the car will be dyno'ed once broke in.
350 TBI / 5.7 Cop car TBI and Computer
Engine was a L98, stock heads, no porting.
LT4 cam
Headman 1 5/8" headers
3" Flowmaster
K&N airfilter
3.42 Posi
265 series tires (8.5" wide wheel, 10" wide tire)
(For the 1/4 time's, I consider myself to be a little above avg driver.) *Waits for flames on that comment.*
For HP, please post RWHP.
Old Feb 28, 2003 | 11:40 PM
vwdave's Avatar
Desktop dyno sez....
(At the flywheel.)
400ft-lb from 2k to 4k rpms. 408 @ 3000 peak
301hp at 4k, and drops off.
/20% =
240hp
320 ft-lbs
Roughly.
Old Mar 2, 2003 | 02:47 PM
NJ SPEEDER's Avatar
that sounds liek not a lot fo hp for the LT4 cam. are you runnign 1.5 or 1.6 rockers with it?
et is impossible to predict really. et is all about chassis prep and gearing. with good traction that kind of power at teh flywheel shoudl translate to mid 13's at around 100mph if you have average tractiopn adn gearing. quicker if you hook and gear it good.
later
tim
Old Mar 2, 2003 | 02:52 PM
vwdave's Avatar
1.5 stamped rockers.
I am guessing low 14's.
Old Mar 6, 2003 | 12:19 PM
BahamutRS's Avatar
You mean a 350 TBI motor, too? Not just the computer, right? Because if it's a 305 forget about it...a 350 will net you some decent times, I would think (with those modifications).
Old Mar 6, 2003 | 06:01 PM
vwdave's Avatar
Re: Power & 1/4 mile predictions
*Looks at quote....*
Yup, its a 350.
Old Mar 6, 2003 | 07:07 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
300hp at fly, and somewhere in the 14s range, maybe high 13s if you have stall (2600rpm range) and exhaust.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
mdtoren
Aug 23, 2015 12:52 PM
jbd1969
Aug 17, 2015 07:06 PM
mdtoren
Aug 16, 2015 05:45 PM
