cam install questions
I just recieved my performer intake and crane compu cam today from jegs and thunderracing. after reading the install instructions, i have a few questions as to what all i will need. First, i know for certain that i need an adjustable fuel pressure regulator. Does it matter what i go with? Secondly, it states that I need new lifters. I very well could be mistake, but can't i re-use the old ones since its a hydraulic roller cam? Lastly, i know i need gaskets for just about everything, but is there anything else i'm gonna need. thanks in advance guys.
Donnie
Donnie
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Yes you can reuse your old lifters IF they're in good shape.
Did you get a new timing chain set? If not you can get a Dynagear replacement at AutoZone.
Besides that and the gaskets, you're good to go.
If you read the tech article, you can make your FPR adjustable.
https://www.thirdgen.org/newdesign/tech/tbi-afpr.shtml
And it wouldn't hurt to do the ultimate TB mods, if you haven't already.
https://www.thirdgen.org/newdesign/t...imatetbi.shtml
https://www.thirdgen.org/newdesign/t...matetbi2.shtml
Next step would be learning how to program and burn your own chips.
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
