b and m tork master tq converters?
Old Mar 8, 2003 | 11:20 PM
burnouts4ever's Avatar
are these anygood, 240 bucks seems like a reasonable price but the thing that bothers me is it says , Engines smaller than 350 cid may not achieve stall speed indicated. one i was looking at is the 2400 one.
Old Mar 9, 2003 | 10:23 AM
Nitroburn's Avatar
That's because stall speed is based and the weight of the vehicle and the torque output of the engine.
Most aftermarket equipment (cams, heads, etc....) with specifications regarding numeric valves labeled for a Small Block Chevy are based on 350-400 cid engines since they are the more popular ones being built.
B&M is simply covering-their-butts by saying that the 2400 stall speed may not be that high in a smaller engine (maybe more around 2100 rpms, for example).
If you go to B&M website and read the fine print on how they come to the stall speed ratings on their torque converters (weight of car, size of engine, HP & torque numbers, etc...) then you'll understand a little more on how to determine what the actual stall might be in your car.
Hope this helps...
Later,
-Mike
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
codeysabatini
Nov 10, 2015 04:07 PM
camaro1185
Oct 26, 2015 06:51 AM
89fast5oh
Sep 8, 2015 09:55 AM
