Is this a worthy cam for my 305 emmsions legal build up
Old Mar 9, 2003 | 09:23 PM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
Is this cam a good performance cam thats still legal to pass emmsions and when i install the cam im planning to install the crane gold rockers 1.6 self,3/8 stud narrow body also how much horse power should i expect to get from the mods. heres the link for the cam.
http://store.summitracing.com/partdetail.asp?part=487
Old Mar 9, 2003 | 09:35 PM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
I think the cam in your link is for flat tappet lifters, you'll need a hydraulic roller cam. Why not go with a LT1 cam or L98 cam? You can find them used for less than $50. They have almost the same specs as the cam you listed. Also plan on changing the valve springs too.
crane cams hyd. roller cams
I just finished swapping in a L98 cam, big difference.
Old Mar 9, 2003 | 10:06 PM
tbfirebird's Avatar
Engine: ??????????
so where could i buy number 3 at here it is
3. For mid and top end torque and HP. Mainly for 87-92 305 cars w/TBI and manual 4 or 5-speed. (50 state legal for listed applications, C.A.R.B. E.O. D-225-22) Basic RPM 1000-4500
Old Mar 9, 2003 | 10:12 PM
vjo90RS8's Avatar
Car: 2002 Z28
i would just go with a used LT1 cam, for about 50 like stated earlier. A new roller cam will set you back about 250 bucks.
Old Mar 9, 2003 | 10:13 PM
tbfirebird's Avatar
Engine: ??????????
at summit i think CRN-104211 for $269.95
Old Mar 10, 2003 | 07:28 PM
NJ SPEEDER's Avatar
you can save your self a lot fo cash and get a strong emissions legal combo by looking at LT1 and L98 cams. they are hydraulic roller which means they don't wear out and it is safe to buy used ones for under $50.
later
tim
Old Mar 10, 2003 | 08:39 PM
Nordbert's Avatar
You might give these guys a call. They used to send me notices containing new crate engine take-out? cams. I think some were roller. http://www.sdpc2000.com/cart.asp action=catalog_start&catid=540
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Reborn756
Sep 4, 2015 03:42 AM
theurge
Aug 21, 2015 12:46 PM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
