CC304 cam in the 305
Old Mar 11, 2003 | 11:26 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
210/220 .500 .510 @.500 114 LSA
The duration is about the extreme I want to go with the 305 and the lift is all my Vortecs can take. LSA is solid at 114, so I can still have a decent idle. I like how it has more intake than the ZZ4 does but I dont know if I'll need the extra a/f. I think it'll be early summer if I do it. It'd be replacing an LT1 cam. Its either the CC304 or 1.6 full roller rockers with the LT1 cam. What do you think?
Old Mar 11, 2003 | 12:29 PM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
I think it should work well with the RPM intake, I assume your vortecs aren't stock since all I read is .470" max lift. I ran the crane 2032 cam in my 305 TPI with MAF though. that's 214/220 and 112 lobe sep(i think?)
It gave me hard brakes at idle and didn't like anything under 1500 rpm, but that shouldn't be a problem with your stall, (change the lock up speed?)
I think the cam would be perfect for you having decent heads and intake for the rpm of that cam, but you'll definately need some tuning to make it work good.
Old Mar 11, 2003 | 02:55 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
I would get that cam over the LT1 cam with 1.6 RR combo.
Old Mar 12, 2003 | 01:07 AM
iroc22's Avatar
The cam looks good to me.
Definitely an improvment over the tiny LT1 cam.
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
beastin91rs
Oct 9, 2015 07:38 AM
michealleger
Aug 26, 2015 03:29 PM
theurge
Aug 21, 2015 12:46 PM
