CAm guys and rocker guys come on in(please
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
Okay first i need to know is this the right LT1 cam.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33614
would theses rockers be a good fit for the cam.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?
ViewItem&item=2407200351
also what rockers should i use this car is going to be a daily driver and a weekend racer.Also i heard that you have to adjust the rockers when the car is runnning because its to hard to tell when its off.And is there anyway i could gain horsepower by changing push rods if so which ones.
THANK YOU FOR THE PEOPLE THAT HELPED ME
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
1. The LT1 cam doesn't say if its a Z28 cam or a Impala SS cam. Big difference in specs.
2. The 1.6 rockers will be too much lift for stock heads and will cause you valve train issues. Plus it doesn't say self aligning. You will need self aligning rockers with those heads.
Engine: ??????????
Engine: 305 TBI
Transmission: 5-Speed
Yeah that cam would work just fine since he says its from a 95 Z28, although just a thought but you might want to look for one from later years I think 96 or 97, I believe they had a little more lift on the exhaust side
Well since it is on subject and kind of applies to this thread I will just post it in here..
Will 1.6 self adjusting rockers work on an LO3 with Torquer S/R heads with an Extreme Energy Cam 268 with an Air Gap Performer RPM intake???
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
Aug 20, 2015 09:36 PM
