car wont start
Old Mar 21, 2003 | 01:04 AM
burnouts4ever's Avatar
car wont start
I hear clicking, i hear the starter make a click sound and vat relay make a sound too, why wont the car start dangit???? is it the vats??? the battery is fully charged too.
Old Mar 21, 2003 | 07:27 AM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Are all of your grounds and leads clean?
Old Mar 21, 2003 | 07:40 AM
TimRS's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
I believe that if your VATS was bad then you wouldn't even hear the clicking of the starter.
Old Mar 21, 2003 | 09:55 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
My VATS experience the engine will crank like mad but never start. Usually a click only with the a good battery indicates a bad starter or a bad main wire from the battery to the starter or the ground from the block to the chassis. The wire problem occurs a lot with the older cars with vibration of the engine and corrosion from the battery terminals breaking down the wires.
Old Mar 21, 2003 | 12:31 PM
well the vats is not the problem, so what else may it be, bad starter?? wires to starter?
Old Mar 25, 2003 | 01:29 PM
CamaroGuy71's Avatar
Car: 2002 TT Corvette
Engine: 5.7L
definately a not enough power to the starter problem. Try jumping the car... any luck? It clicks like that when it does not have enough power. That sound is the starter gear engaging then disengaging with the flywheel/flexplate because there is not enough current to it.
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
