tbi to carb swap
Old Mar 29, 2003 | 08:35 AM
89firechicken's Avatar
tbi to carb swap
ok i removed my tbi to put a carb in it's place. and in process of that i got cut happy and removed the computer and i think all the wires that go to it. my question is when i turn the key the fuel pump doesnt prime and the starter doesnt turn? anyone go through this before? also my car does have vats but i dont see the security light at all is there something i have to do for the vats as well? thanks guys..
Old Mar 29, 2003 | 08:49 AM
DABE's Avatar
VATS is not computer controlled....i have no ECM and i still can turn on the car...and vats is still installed and working...we tried another key we cut with the diff chip and it didnt start
Old Mar 29, 2003 | 09:16 AM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Vats is computer controlled, its just a flag in the prom that can be enabled or disabled. It simply won't let the injectors fire. If your car still won't start it must be because you pulled a power wire that was controlled by the vats (maybe dis power), and with no ecm the vats must default to "on".
Old Mar 29, 2003 | 09:47 AM
so do you suggest i hook the vats wire up to some power wire to by pass it or complete the circuit? and for you guys that rewired your fuel pump did you just use a switch or is there some where you can splice into.
Old Mar 29, 2003 | 10:53 AM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
I'm really don't know much about vats, as I don't have it, I believe there are relays (or the vats modual itself) that give power to the fuel pump relays, and the starter, I would just think that you need to take your wires right from the ignition. ie: run wire to fuel pump, and starting wire to starter. But there has to be an eaiser way. Try some searches on disabling vats.
Old Mar 29, 2003 | 07:01 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
I re-wired my fuel pump. Found the power wire for it and ran it to the fuse panel to a location that is hot when the key is on.
Old Mar 29, 2003 | 11:38 PM
DABE's Avatar
welp...if vats is not computer controlled...why doesnt it start with a different chipped key....and it does with the right one???
my computer is out of the car...
Old Mar 29, 2003 | 11:50 PM
I have heard that VATS can be disabled in the computer also, but by your case the actual system is not controlled by the computer. Does this make any sence, probably not I have been awake for eighteen hours now...
Old Mar 30, 2003 | 09:59 AM
DABE's Avatar
yeah it makes sense...
vats is not computer controlled on my 92 tbi....well..carb now
Old Mar 30, 2003 | 10:49 AM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Yeah, Vats can be disabled (controlled) by the chip, but with ecm gone vats must default to always being on.
Old Mar 30, 2003 | 05:11 PM
where on the fuse box does the pump go to? i'm just going to use that spot to rewire my pump. oh yeah and the three wires that come from the fuel pump (black, pink, and tan with white stripe) the pink is for the pump right?
Old Jul 8, 2003 | 07:45 PM
badxs's Avatar
the dang ecm isnt there to power the fuel pump rellay
Old Nov 16, 2006 | 01:00 AM
z28_1978's Avatar
I just had my 91 RS's pump apart today, black appears to be a ground, tan goes to pump, pink goes to the sender for the fuel gauge.
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
cstrobel65
Aug 15, 2015 10:19 AM
