rocker arms
Old Mar 30, 2003 | 09:03 PM
cr125r's Avatar
Car: 1988 trans am
Engine: 5.7 gm H.O. crate engine
rocker arms
would it be worth it for me to get a different ratio rocker arms for more valve lift using the stock cam? if so, which?
Old Mar 30, 2003 | 10:11 PM
steve8586iroc's Avatar
Are you asking which brand and type or what ratio? As far as brand goes it depends on what you want to spend. If that was all i was going to do for a while I would go with some 1.6/1 roller tipped rocker probably from Comp Cams.
Steve
Old Mar 30, 2003 | 11:43 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
I did an intake swap at the same time as installing the 1.6 ratio rockers. It was definetely a nice gain. Not the same as a camshaft, but still nice, and a lot easier and cheaper. If you can find the rockers for a descent price and don't plan on swapping cams, then go for it.
Ed1LE
Sep 30, 2018 09:14 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
