Code 44
Old Apr 2, 2003 | 11:35 AM
vwdave's Avatar
Code 44
I got a code 44 (Lean Exhaust.)
It throws the code when my car is idling (Around 550 RPM's, when you start noticing the Cam Lope.)
Any ideas? The O2 sensor is new.
Old Apr 2, 2003 | 02:25 PM
vjo90RS8's Avatar
Car: 2002 Z28
are u using a custom chip, if not, im sure that is causing you to run lean. Might want to try increasing the fuel pressure and messing around with the timing.
Old Apr 2, 2003 | 07:12 PM
vwdave's Avatar
Nope, stock chip from a 350 TBI Caprice.
12* BTDC at idle with the computer jumped.
13lbs of fuel pressure.
350 Injectors.
I am also getting 5-10 mpg.
Old Apr 2, 2003 | 07:36 PM
vjo90RS8's Avatar
Car: 2002 Z28
custom chip, im sure thats all you need.
Old Apr 2, 2003 | 07:38 PM
vwdave's Avatar
I'll have to get winaldl and record the data and have tbichips do it.
Old Apr 3, 2003 | 12:27 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Have you looked at the spark plugs to see if its actually running lean or that the 02 sensor is whacked tell the computer that its running lean when its not and the computer is dumping fuel to compensate causing your 5-10mpg. No amount of chip work will cure inaccurate sensors. The winaldl will help spot some flakey readings from them though. A vacuum leak could also aid in your problem. Can't rule out the CTS (coolant temp sensor) either. But I would say that its one of those problems rather than the chip. Yes you could gain some power from a tuned chip but it should run a hell of a lot better than that with your chip.
Old Apr 3, 2003 | 07:05 PM
vwdave's Avatar
Found the problem. The headers melted the connector and wire for the Oxygen Sensor. It was telling the car it was lean and it richened it to hell. I figure it did it on tuesday. The mileage wasn't too bad, until the codes started flying, and the mileage went to the floor.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
