SES light
Old Apr 6, 2003 | 10:45 AM
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
SES light
i am getting this light once every month and a half or so its not staying on and my car is running fine it keeps coming up as code 32. Fault in barometric pressure sensor circuit OR
Fault in exhaust gas recirculation valve diagnostic switch OR
Fault in electronic vacuum regulator valve
what could cause this has anyone else had this problem its getting annoying
Old Apr 6, 2003 | 11:06 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
If it's only coming on when you are at a steady cruising speed (like around 60 MPH) then it's more than likely your free flowing exhaust coupled with the low RPMs of cruising.
This seems to be a common code people get. Evidently the EGR needs some backpressure (something that actually does need it ) to work properly.
Old Apr 6, 2003 | 11:32 AM
Frik92RS's Avatar
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
I've had the same problem on the same motor for awile now, here's whats happening. When you are cruising down the highway and the computer is in closed loop operation (its at normal temperature and using input from the sensors to figure out how to manage the motor), the computer every once in awhile looks at the output from the O2 sensor when it knows the EGR is on, or it thinks it is, and knows it should have a certian output based on the EGR being on. When it doens't see that then it sets a code 32 thinking that the EGR is not functioning. But in reality it is, but you've increased the exhaust outflow which decreases backpressure which is actually necessary for the valve to work properly. Its nothing you really need to worry about unless you live in an emissions state (like me) then you'll probably have a hard time passing (like me). Another factor that can contribute to it is a lower temp thermostat. Chevy actually ran these motors at very high temps (220-230) to improve emissions since at the higher temperatures the fuel burns more completely therefore reducing HC emissions. So if (like me) you have say a 180 stat in there your emissions will be increased which makes the computer think that the EGR isn't working setting a, that's right, code 32. Phew!
Theres more info at https://www.thirdgen.org/newdesign/t...diagnose.shtml
Old Apr 6, 2003 | 02:23 PM
Engine: LO3 and LT1
well that would explain it i have headers and a straight 3 inch and also a low temp thermostat and the light only comes on a low cruising speeds thanks
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
