roush at hot start up
Old Apr 15, 2003 | 10:30 PM
SlowMaro's Avatar
rough at hot start up
so here goes, ....car will run FINE, all day long, until i shut it off, and crank it again, after tha it runs ROUGH as hell and just dies.....once again, ..itll fire right u and run fine if the car is cold.....but after its hot, and i start it again, ..sputter sputter .....glug....dies....any clue anyone??
Old Apr 16, 2003 | 12:17 AM
knoxbonnie's Avatar
Check your Ignition Control Module. They will check it at Autozone for free.
But, on mine, it checked out fine on the AutoZone tester, and when I replaced it, my problem was fixed.
Old Apr 16, 2003 | 12:20 AM
SlowMaro's Avatar
every single thing on the ignition is brand spankin new less than a week old, ive bene replacing EVERYTHING trying to fix this with the most random ideas, ....coil, cap , rotor, dist, ignition module, wires, .plugs......any more ideas?? any sensor that could cause this?
Old Apr 16, 2003 | 07:40 AM
txhotRS's Avatar
I'm no expert .. but try the EGR valve.. It uses HOT exhaust gas to create a stabilizing vacuum with the manifold... there is a small vacuum hose conected to the side of the EGR valve.. Once the car warms up, TURN IT OFF ... disconnect the hose and plug it with a small screw or something (something that makes a seal) then start it back up... If the idle levels out... and the car runs smooth... change the EGR and YOUR GOLD,... if that doesn't work... check ALL vacuum lines going to any engine sensor... the MAP sensor, the TPS, all that crap, make sure they don't have any cracks, splits, rotten connections... If none of that works... I hate to say it... BUT check and or replace intake manifold and injector gaskets.
GOOD LUCK
Old Apr 16, 2003 | 08:59 AM
SlowMaro's Avatar
egr valve that golden thing behing the tbi on the pass side ...connected to the manifold????
Old Apr 16, 2003 | 09:07 AM
vjo90RS8's Avatar
Car: 2002 Z28
yeah, thats it
theshackle
Mar 5, 2017 06:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
