Problem with spacers and idling
Old Apr 21, 2003 | 11:33 AM
BowtieFever's Avatar
I bought a 1/2" TBI spacer and a 1/4" Injector spacer. They were made out of wood and I painted them w/ engine enamel. When I took the throttle body & Injector pod off........i cleaned them both with an all purpose cleaner & degreaser. I then put the throttle body spacer back on with a gasket on both sides (Had to get longer bolts). I did not put a gasket on with the injector spacer.
Now the problem, it idles really high and at times rough. It's almost like I have a leak (vacuum). But, everything is hooked up fine. Could I possibly of messed up one of the sensors cleaning it (IAC, TPS)?
Any Ideas??? Thanks!
Old Apr 21, 2003 | 01:35 PM
jos4570's Avatar
I am having the same problems...see my post below.
Old Apr 24, 2003 | 08:07 PM
jos4570's Avatar
The problem is in the TBI spacer. I removed it, and it idles fine now. I just managed to twist off a fuel line and screw up the soft aluminum fuel threads in the injector pod.
I guess you have to modify the throttle cable, or put some spacers on the throttle bolts? Either way, the spacer is the problem. It is either causing a vaccum leak or interfering with the throttle bracket.
The spacer width varies by 1/16", and isn't cut very precisely. Also easily cracked.
This is it for TBI mods for me.
Old Apr 30, 2003 | 04:17 PM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
Well that would be your problem. Sure, people used to make carb spacers out of wood in the old days, but with such a huge SBC aftermarket out there now, why would you even consider a wooden TBI spacer? Order one from a reputable company made from steel or aluminum and I can bet you will be more than pleased with it. Where did you get that one anyway? It looks like someone didn't even know how to use a jigsaw or a hole cutter when they made that.
Later,
Harry
Old Apr 30, 2003 | 05:26 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
i think his is homemade.....
Old Apr 30, 2003 | 06:09 PM
1MEAN92RS's Avatar
Engine: LO3
Re: Problem with spacers and idling
Originally posted by BowtieFever
I bought a 1/2" TBI spacer and a 1/4" Injector spacer. They were made out of wood and I painted them w/ engine enamel...
N/M 2 different people. I should really be more carefull about reading posts.
customblackbird
Aug 15, 2021 10:16 PM
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
