any injectors for sale??
i need a set of injectors that will work with a 92 305 rs....tbi obviously. would be GREAT to get the 65 lb cop injectors.....any mods i have to do for the 65 lb injectors?
I just installed 65 psi cop car injectors in mine and they dump WAY too much fuel for my 355, but to make up for the fuel I am installing another intake that I board the holes to 2" for a 454 TB maybe this will help with the air flow, I hope, I have the injector part #'s if you need them. As far as the stock TBI the best thing I did to mine was the TBI mod in the tech section and the AFPR, but I really think that the 65 psi injectors will be too much for your engine. You might try a set of 55 psi injectors, I wish I would have gotten them, but I have been told that the cop car injectors are very hard to find.
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Assuming you're using the stock injectors, you will need your chip adjusted if you go w/ the 65pph injectors. I wouldn't imagine it would take that much work, just some adjustment to the fuel tables and maybe some extra timing at higher rpms.
9192camaro
16
Feb 3, 2019 12:21 AM
New2Chevy
Oct 4, 2015 11:27 PM
