Fuel Pressure
Old Apr 26, 2003 | 12:16 AM
txhotRS's Avatar
Fuel Pressure
Can anyone TELL ME what the STOCK fuel pressure is on a 305 TBI ('89 if it helps)
Thank you so so much
Old Apr 26, 2003 | 01:25 AM
Frik92RS's Avatar
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
The stock fuel pressure was set from the factory somewhere between 9-12psi. Chevy didn't seem to have a set number for their units coming out of the factory because I've seen them all over that band.
Old Apr 26, 2003 | 12:38 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Mine was between 11 and 12 psi.
Old Apr 27, 2003 | 06:28 PM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
mine was at 10.5
Old Apr 27, 2003 | 08:05 PM
badxs's Avatar
10.5 here, end all my books say 9-13 psi, allso the should flow 1 gallon a min for volume, remember it doesnt have to have baerly any volume to put out 9-13 psi so its criticall to check too
Old Apr 29, 2003 | 04:04 PM
89IRO's Avatar
What is the stock fuel pressure on my '89 IROC-Z 350 TPI? I heared that after exhaust (including headers), ignition stuff, K&Ns, air foil, gears, etc... a good setting for an aftermarket afpr, is 50 psi. So what is mine stock? -89IRO
Old Apr 29, 2003 | 07:23 PM
badxs's Avatar
i do believe its around 35-45 psi stock so 50 would be good for a little more richness
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
