performer manifold
Old Apr 30, 2003 | 03:17 PM
SlowMaro's Avatar
performer manifold
question, i have all the smog crap on my car, ...the performer i have is not egr equipped, ...can i safely not hook up the egr and not have any problems or SES lights, ...secondly, the heater core hose goes into the back of the stock manifold, ..theres not not one on the performer, its on the front....do i stick it tjhere?? help please, ... i have the holes bored out for the manifold already ''86 manifold'' so now what
Old Apr 30, 2003 | 03:51 PM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
In order to do away with the EGR you are going to have to turn it off in the ECM or else it will throw fits and your car will not run correctly. As for the heater hoses you can run one to the manifold and one to the water pump just like an old hot rod setup and you wont have any problems.
Old Apr 30, 2003 | 10:14 PM
SlowMaro's Avatar
thats pretty much like it is now right , other than the hoses going to some black plastic connector deal near the front of the engine, pass side.
Old Apr 30, 2003 | 10:28 PM
Frik92RS's Avatar
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
That plastic thing is the heater control valve. Basically its the thing that regulates whether or not hot coolant flows through the heater core to give you heat, or not.
Old May 1, 2003 | 12:30 AM
SlowMaro's Avatar
so ....keep it?? maybe that bastard is broken....my car never put ou tGOOD heat, only so so heat
Old May 1, 2003 | 03:08 PM
SlowMaro's Avatar
question, ....line that runs off the stock manifold to the master brake cyl.......where do i run it on the performer??
Old May 1, 2003 | 04:14 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
My thermostat do you have.
Old May 2, 2003 | 01:04 PM
1MEAN92RS's Avatar
Engine: LO3
I did away with it and put in one of these. If your car isn't putting out good heat then it's probably the thermostat. Just plug the bypass hole in the radiator and drill a small hole (like 1/16") in a 180* thermostat. That'll keep some coolant circulating all the time to help eliminate hot spots on warmup.
Old May 2, 2003 | 04:35 PM
JPrevost's Avatar
Car: 91 Red Sled
Where would I find one of those valves? I don't like having the "cars venting system" pushing air past my always on heatercore..... I have a ball valve I was going to install but it is too heavy and I like the looks of the one you posted.
Old May 2, 2003 | 06:34 PM
1MEAN92RS's Avatar
Engine: LO3
Jon,
You can get a manual heater valve at just about any parts store. They usually have to order them though It's made by Stant and the p/n at Advance is 20500 for the 5/8" valve and 20501 for the 3/4" valve. If they can't find it (stupid parts store people) then have them look up a 1971 Camaro V8 4bbl and it should be one of the options on the screen. It does take about 15 turns to completely open or close the valve (much more than a ball valve), but I only do that twice a year so it's not really a problem.
Later,
Harry
Old May 2, 2003 | 06:44 PM
1MEAN92RS's Avatar
Engine: LO3
I dont' really have any pics of the valve itself, but you can see how uncluttered the framerail is without all that crap over there. Next thing to go is the AC. It's slinging oil all over my hood right now and I just don't have any use for the extra 50lbs it adds
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Veaceonee
Sep 29, 2016 08:15 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
