Fuel injectors????
Old May 1, 2003 | 10:26 PM
fbodyandy's Avatar
Fuel injectors????
i have a 91rs 305 and 5 spd.110k on it i think my fuel injectors a bad but they only have 1.4 ohms of resistance. they make a racket, all that loud clicking is almost enough to drive me crazy when under the hood. i also notce that they dont seem to spray evenly all the time at idle. it idles at about 650 to 1000 Rpm. the idle just kinda goes up then down up and down ect. i have not done any thing to the car other than the open element filter, plugs, wires, cap, suspention stuff and breaks, oh ya and a fuel filter.
injectors are a lil expensive for me so i just wanted some people to say... yes it could be injectors or no dont spend money on them.
thanks guys... i dont know where i would be with out this board
Old May 1, 2003 | 10:55 PM
25THRSS's Avatar
tbi injectors always make that clicking sound no matter what. Get used to it, lol.
Old May 2, 2003 | 12:36 AM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
If you see them spraying unevenly I'd say before you go replacing injectors just buy some of that fuel system cleaner stuff and run some of that through it, it may do the trick or it may not but you're only out like 5 bucks or so.
Old May 2, 2003 | 02:13 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
What do you mean by firing unevenly? The spray is supposed to alternate between injectors. Are getting any codes in relation to your idle issue?
Old May 3, 2003 | 03:10 PM
BronYrAur's Avatar
Engine: 305 TBI
I interpreted this as that the injectors aren't spraying a consistent even cone like they are supposed to.
Old May 3, 2003 | 06:34 PM
fbodyandy's Avatar
correct they are not an even cone
Old May 4, 2003 | 12:01 AM
91FB305TBI's Avatar
I just had to replace one of my injectors, but it was basically dry at low RPM. The car did not run well at all. About a week before it gave out completely, I noticed an occasional erratic idle where the engine almost would die. The bad injector measured about 1.3 ohms verses 1.5 ohms that the other injector measured. The new injector measured 1.5 ohms also.
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
