Cross--Fire ???
Old May 4, 2003 | 07:30 PM
StreetRCR's Avatar
Car: 82 Pace car
Engine: Small block
Transmission: TH350
Cross--Fire ???
What is the biggest cubic inch motor I could put under a Cross--Fire Set up? I have bored out the TBI's and ported the Manifold? Where can I get a chip burned for the bigger motor?
Also do they make an aftermarket intake? And I was thinking of swapping in a T10 four speed---has anyone done this???
I know it's a LOT of questions, but I want to get this rolling before Summer ends.....
TBI's are 1.5 mill. bigger with stock injectors. Fuel pressure is currently set at 15 psi
Old May 4, 2003 | 08:18 PM
jase's Avatar
Tom cfi400 has a 400.Ihope that is correct.Try a search or look for tom CFI.
Old May 5, 2003 | 05:13 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
YUP. I had a SBC 400 sitting under my CFI intake.
Old May 5, 2003 | 09:58 PM
StreetRCR's Avatar
Car: 82 Pace car
Engine: Small block
Transmission: TH350
Who did your work as far as Computer and tuning and how big was the cam?
Old May 6, 2003 | 08:54 AM
Engine: LT1, L400
Read the sig :)
Hey there. It's all in my signature, but again, the ECM, and the PROM chip were stock and original. All the tuning I did to make it run well included changing injector sizes, fuel pressure, and utilizing a vacuum refferenced fuel pressure regulator, similar to those found on MPFI engines. I ended up with 75pph injectors, with a fuel pressure of 14.5 at WOT and ~10 PSI at idle (15" of vacuum @7000' elevation).
The cam was 224/234* int and exh. I don't remember the lifts, but the LSA was 114*
It would get me 25 mpg on the highway, and the check engine light never came on. I didn't ever check the emissions, because you don't have to where I lived in Maine, and now in Utah.
Old May 6, 2003 | 04:07 PM
StreetRCR's Avatar
Car: 82 Pace car
Engine: Small block
Transmission: TH350
Thanks> All these questions were for a friend and he is really excited that this will actually work. It all sounds relatively easy. Coincidentally he is also a snowmobile freak and take at least 2 trips a year to Wyoming. Nice sled, he is also a Polaris nut
Old May 6, 2003 | 06:09 PM
Engine: LT1, L400
LOL abou the the sleds! Yea, I love that sport, nothing beats it IMO. Anyway, if your buddy runs into trouble, have him drop me an email:
tkendrick@thecanyons.com
Later!
