TBI clearance
Old Apr 30, 2003 | 07:44 PM
txhotRS's Avatar
TBI clearance
OK, does anyone have the height specs on the STOCK TBI intake manifold.???
DOES ANYONE HAVE THE HOLLEY TBI MANIFOLD.?? if you do, does it fit under the stock hood?? will it fit under the stock hood.. If I have 14x3 air cleaner ??, I know the edelbrock TBI performer will fit ... but DOES ANYONE have the 1" TBI spacer... what sort of clearance does this give you, with either the edelbrock, or the holley, ??? does it really make THAT MUCH of a difference
thanks guys...
ANY advice, ideas, are welcome:hail:
Old Apr 30, 2003 | 10:38 PM
vjo90RS8's Avatar
Car: 2002 Z28
i have a 1/2" TBI spacer, 14x3 flat based open element with a flat top, and the stock intake and i am pushing the limit. A 1" spacer would probably fit with a drop base but youll have to do modifications to the throttle linkage and TV cable which might not back it worth it, thats y i went with the 1/2". I hear that the edelbrock intakes dont benefit from the TBI spacers because they already have longer runners compared to the stock intake so that is a plus with hood clearance. Same probably goes for the holley 2" tbi intake, but if you want to use EGR youll need a 5/8" spacer so that your TBI will clear the valve.
Also do a search on these intakes, questions like this are asked almost everyday.
Old May 4, 2003 | 11:40 AM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
This might help you out......although I never did get any sort of response from anyone on thsi one..and the intake is goign on in about 1/2 weeks
https://www.thirdgen.org/techbb2/sho...=intake+height
Old May 4, 2003 | 01:08 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
The stock manifold is the same height as the Performer RPM without the tbi adaptor.
The holley pro-jection fits under the stock hood fine, I cant tell you how much clearance you'd have though. The performer rpm + holley adaptor rubs the bottom of my hood so I cant put a wingnut on it.
Old May 4, 2003 | 07:42 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Like I said I will be ripping into mine in the next week or so...I will keep you guys posted as to what my outcome is.
Old May 5, 2003 | 08:06 PM
txhotRS's Avatar
tanager,
you are a G O D... thank you so so much, and please, if it's not too much trouble.. keep me posted, I don't have the budget to experiment with intakes... THANKS
Old May 5, 2003 | 09:02 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Geez that is the first time I have been called that...ha ha ha.
I will be sure to keep you posed on things etc....if you dont hear from me just drop me an email...d2kearney@sympatico.ca...and I can fill you in on things as I end up finishing things.
D
Old May 6, 2003 | 01:19 PM
mylittlemule's Avatar
Car: 87 Wrangler
Engine: 355 TBI
So how do you put a 14x3 Aircleaner on without using the spacer rings? My coil and TPS sensor is in the way on mine.
Old May 6, 2003 | 05:26 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
you have to use a non-drop base cleaner....or is it the other way around.....I cant remember...but I know you can use the one and not the other.
Old May 6, 2003 | 05:38 PM
Snowdog 91 Formula's Avatar
Yes and No...
Yes it will fit without the spacer and a non-drop base cleaner. Unfortunately, if you need the EGR valve, you have to have the spacer for it to fit. If you put in the spacer, you will need to have something like a 14 x 2 or 2.5" cleaner..... Or you could do what I did and get the ASCD hood! No space problems with my setup.
Old May 6, 2003 | 08:07 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Ya I bet you dont have any hood clearance problems ha ha ha.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
91 SrS
Oct 7, 2015 04:32 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
