LT1 cam gurus...please help...come inside
Old May 13, 2003 | 08:19 PM
raggedout91RS's Avatar
Car: '84 Z28
Engine: Goodwrench 350
Axle/Gears: good guess
Allright guys, I got this cam off of some dude over tthe net and I wanted to check the lift to make sure it was legit. I picked up my sliding caliper and measured the base circle the best that I could and it measured out to be 1.233" and then I measured from the tip of the lobe to the back of the base circle and it measured 1.542". Then when I measured my LO3 cam the base circle came out to 1.335 and the lobe came to 1.589. The Lt1 came comes out bigger if you subtract the difference but is this right and why is the base circle bigger on the stock LO3 cam?
Old May 14, 2003 | 06:31 AM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
Cam from Some dude
1.542-1.233 = 0.309 inches lift
LO3 cam
1.589-1.335 = 0.254 inches lift
These are both lobe lifts so you have to multiply by 1.5 to get the lift at the valve:
LT1 cam (from Dude) = 0.464 inches
LO3 cam = 0.381 inches
These are both close enough to the factory values for lift, i.e. they are within any measurement error or manufacturing tolerance, or both. As far as why the base circle is larger on the LO3, it's becauseif they made the base circle any smaller than what they have, and kept the same lift, they would need longer pushrods. GM likes to use the same pushrods for many applications, so they intentionally use a smaller base circle on hotter cams having higher lift. If you think about it carefully, it makes sense. HTH.
Old May 14, 2003 | 06:27 PM
Car: '84 Z28
thanx alot man, that sure explains it.
Frozer!!!
Jan 19, 2024 04:55 PM
1984HO
Mar 19, 2021 11:59 AM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
midge54
Aug 29, 2015 09:51 PM
