If you've seen or have a intake thats not stock come in and help please
Old May 17, 2003 | 11:44 PM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
okay heres a link to what im looking for something like that
http://cgi.ebay.com/ebaymotors/ws/eB...category=38634
i was looking for something like that but that has 2 inlets because im going to make a cold air intake instead because my open element filter takes in tooooooooo much hot air after driving around for a while which really takes alot of noticable power away.Im going to put my battery in the trunk and that empty spacer where the battery was on the passanger side so im going to put a cone filter connected to a aluminum dryer duct to the intake system im trying to find and the drivers side will be the same so nothing but cold air going to the engine.
Old May 18, 2003 | 12:34 AM
25THRSS's Avatar
You could buy a dual snorkel intake or buy the ram air box.
Old May 18, 2003 | 08:14 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I just made a dual snorkel myself - cut a hole in my air cleaner housing, attached another metal snorkel with rivets and JB Weld, put flexible hosing on there from AutoZone, added extra plastic scoop on pass side. I removed my coolant overflo bottle, switched to the smaller bottle, and put it under the plastic cover under the hood latch - noticable difference, cost under $20, looks nice.
Old May 18, 2003 | 10:11 AM
tbfirebird's Avatar
Engine: ??????????
25thrss i would use the dual snorkel but it cost alot and it really isnt a smouth flow and the ram air box is just to big i need to get the air to the engine with little distance and the ram air box and dual snorkel will get pretty hot after driving around for awhile.
Old May 18, 2003 | 08:12 PM
steve8586iroc's Avatar
Try using 3" aluminum dryer duct and then insulate it to keep it from picking up engine heat.
Steve
Old May 19, 2003 | 10:18 AM
GNVAIR's Avatar
Try this place http://www.ramairbox.com/
Old May 19, 2003 | 12:52 PM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
This was made from a 93 caprice air box, custom plenum and a stock 91 air intake.
Clears the hood and is working well.
S-D
Attached Thumbnails If you've seen or have a intake thats not stock come in and help please-camaro-intake-front1.jpg
sweet_87_iroc
Sep 25, 2015 10:01 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
PestilenceIV
Aug 20, 2015 02:33 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
