Results of LT1 cam, 416's, and intake swap...LONG
Car: '84 Z28
Engine: Goodwrench 350
Axle/Gears: good guess
Well I finally got it all straightened out and started it up. It runs rich as hell. If it idles for a few minutes it will flood out and I have to churn it over for about 30 seconds at WOT for it to start again. The idle seems to fluctuate between 500 and 1100 RPMs. Lots of black smoke when I rev it. I am throwing code 15 and 42 as of now. I'dont know why the CTS is acting up cuz it worked fine before. Also the trans shifts way too soon. I adjusted it as tight a I could, but ran out of adjustment. Here is what I did.
-LT1 cam
-LG4 intake w/ adapter plate
-unported 416's shaved .030 w/ new E-brock springs
-new timing chain
-new O2 sensor
-removed EGR
-removed AIR system and pump
I think thats it. Any ideas on leaning it out?
-LT1 cam
-new timing chain
-new O2 sensor
-removed EGR
sounds like you screwed something up, like the dist. is in the wrong position or you didnt reconnect the cts. the reason its rich as hell is because of low vacuum caused by any of those conditions (could be a vacuum leak too, or did you forget to reconnect the map sensor?) lots of things could be at fault it should run somewhat decently though if its not you have a mechanical problem
Car: '84 Z28
Well it runs alot better now. I replaced the CTS and set the timing at 10 degrees and seems to run alot better. I have'nt messed w/ the fuel pressure yet but prob. will in the future. It does feel a little faster on the top end but I wont really know until I hit the dragstrip.
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
You need to cut a lot of fuel near idle and add timing in low rpms. That definately turned around my throttle response and power down low after my L98 cam swap.
Custom chip will lean it out, or maybe a Vafpr that will cut the fuel pressure way down at idle.
Car: 2001 Camaro SS
Transmission: A4
Engine: LS7
Originally posted by DSLDUDE2001
did you burn your own custom chip?
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Hey man, if you want a bin for the LT1 cam I can send you mine, its for vortec heads and a performer rpm manifold but its better than nothing. EGR is disabled, the spark tables are a little advanced, and the fuel table is toned down at idle quite a bit. Its not nothing other than spark done to it for performance, but it made my car a hell of a lot more driveable.
PM me
PM me
Car: '84 Z28
Hey Chuck, that would be great. I'm trying to get my burning equip. together now so I'll prob. need it in the near future. I'll send you a PM sooner or later. Thanx
