Walbro 255 install, still no fp?
Old Jun 6, 2003 | 08:41 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
I just had the walbro 255 fuel pump installed-the high pressure one capable of 60+ psi. Well, I checked the fp under load, and it is still dropping when under load, causing me to go lean still. The fp pressure still doesn't go past 15psi, even though my regulator is rated at 22 psi max. Any ideas? this is very frustrating.... stock fuel line other than braided running from the rubber lines to the tbi.
Old Jun 6, 2003 | 10:17 PM
steve8586iroc's Avatar
Could be a restriction between the pump and the tb. If you could check the pressure at the filter you might be able to tell if it is a restriction problem.
Steve
Old Jun 7, 2003 | 01:13 AM
89fastlookinRS's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Maybe you could use a vacum assisted regulator. From what I understand a vafpr will assist the sudden drop in fuel pressure by supplying vacum. Other than that maybe check with brian and see if it's chip related? Mine drops 1 or 2 psi under quick snaps of the throttle.
Oh, I also replaced my fuel pump relay when I did my walbro swap, just to be sure everything was in new and working order. It's only 3 bucks I think.
sweet_87_iroc
Sep 25, 2015 10:01 PM
zayne0
Aug 24, 2015 07:22 PM
hayesaw0210
Aug 23, 2015 11:15 PM
AkDrifted
Aug 17, 2015 07:45 PM
