ok guys give me an estimate 1/4 time
Ok well all of my mods are listed in the sig, but i also just installed a set of fully ported and polished on the exhaust side L98 heads. I also deleted smog and A/C system which i know equals almost no hp but it does free up quite a bit of weight, so my question is any ideas of what i should be running? I know what my car ran before in the 1/4 but im interested in learning how much i will gain from getting rid of those horrible swirl ports and adding the new heads and dropping some pounds. Thanks guys
I'd say high 13's. With a 350, you could go with a larger cam like the LT4 hotcam or something similiar to that. If you had headers a larger cam and good tune/traction I'd say that you may be close to the 12 range. Your motor is pretty much what what I'm trying to build so if you ever do run it would be interesting to know how well you do.
