are the 65 lb injectors worth it?
Old Jun 21, 2003 | 12:07 PM
SlowMaro's Avatar
are they worth the money?? will they add any noticable hp?? i plan on putting on ported n polished lb9 heads so i was figuring i needed the extra fuel flow for them.
anyone have the 65 lb injectors?? did they help anything at all?
Old Jun 21, 2003 | 02:16 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
After you swap those heads you are definetely going to want to use the 65pph injectors. Just keep in mind you will need another custom prom to compensate for both the heads and the injectors.
Old Jun 21, 2003 | 02:45 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
I've changed my thinking about big injectors. Since the 65 and the 80 and 90 pound injectors are expensive and hard to find. I think its better just to run the stock 350 injectors at higher pressure. After my 90# injectors crapped out a little while ago, I just cranked my fuel pressure up to 35psi with the 55# stock injectors (roughly 105 lb/hr). No problems yet, and if they fail, the 55# can be found at junkyards and "pick a parts" for cheap.
And as far as a new pump, walboro makes a unit that supports 600hp, for $95. Thats cheaper than new injectors.
Old Jun 21, 2003 | 03:14 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Injectors do not add horsepower if you do not need them.
Old Jun 21, 2003 | 03:19 PM
SlowMaro's Avatar
well, i have them in my hands, funny thing is, they werent hard to find at all, i got em at napa lol....had to search a good bit though
so to make sure, the part # for these is 17112400
they dont look any different than the 55lb ones.. in any event mine were spraying un even so i figured, same price for the 65 lb. might as well get em.
so there will be NO difference when i stick these in??
i wasnt aware they made 80 and 90 lb. tthey do anything different? any mods needed to run them??
Old Jun 21, 2003 | 04:04 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
To run the bigger injectors, you need to tell the computer what size they are, so it doesn't think that the stock ones are still in there. Its just one value in the prom. The old rule about injectors is a good one to follow. 1 pound of injector supports 2hp, so 65# will support 260 hp +/- a little.
Old Jun 21, 2003 | 06:18 PM
SlowMaro's Avatar
so what happens if i run the injectors with the custom prom i have?
i got it from Brian @ tbichips.com, real good guy, in fact he will prolly re burn the prom for a few bucks if any charge at all.
i drove the car after i installed them 10 mins ago, drove perfect, in face it gained back a lil lost sluggishness.
im going to have the 55 lb injectors cleaned real well and sell them if anyone wants them.
they didnt run bad , i just wanted the 65 lb ones because im putting better heads on and wanted it to deliver enough fuel for the lb9's i have sitting in my garage.
figured id run the 65 regardless, not change the fuel pressure, and id be safe til i put the new heads on and get a afpr. run it at 18-20 and be good to go.
correct me if any of my judgement is incorrect.
EDIT:
so basicly, the 65 lb injectors will support the hp i have currently due to all the mods?
do i need higher lb injectors for the Lb9's? 80, 90?
Old Jun 21, 2003 | 07:23 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
The reason the car runs fine is because the computer has an "auto learn capability" so its compensating for the larger injectors @ part throttle.
The 65# should be good enough whatever you do, look at me, I'm running 55# cranked up, and hoping for 13.5s - 14.0s (4200lb truck) track times real soon (as soon as I get my dumps welded into my exhaust)
Old Jun 21, 2003 | 07:27 PM
SlowMaro's Avatar
eithr way im gonna get brian to write a new chip for the lb9's, so ill just get him to add on the 65 lb injectors and take off the smog crap --nods--
this is going to be the badest L03 ever!! well, at least ...itll be a good L03 lmao
considering only the block will be L03, the rest, uhm....half napa parts half random parts comanies i.e. msd, edel. etc etc etc etc etc
this car is no longer gm lolol
Old Jun 22, 2003 | 10:23 AM
Engine: LO3;383tpi
Generally, the reason people swap to larger injectors instead of turning up the fuel pressure to compensate is because too much fuel pressure can cause idle problems with certain engine combos. Some people can run high pressure at idle and get away with it. Low C1500s sounds like it runs pretty good at 35psi, JPrevost runs his @ 28psi, and I'm running at 22psi without an idle issue. However, that isn't to say that your combo would run as good at idle w/ high fuel pressure, so going to 65pph injectors wasn't a bad decision.
Like Low C1500 said, the Walbro 255 is a great pump which you may consider installing, you are going to be getting to the point where your stock pump isn't going to be able to keep up.
Also, a custom prom is never a bad idea when doing mods such as heads. They are going to change the fuel and spark values needed for optimum performance.
Old Jun 22, 2003 | 10:33 AM
SlowMaro's Avatar
yeah, i got em *just in case* besides i had the choice of getting either the 55 or 65 for the same price.
it turns out i didnt need new injectors though, wonder if i can send these back lol
oh well, im going to go check my oil pan, i bottomed out my car on a damn dip in the road i didnt see.
lets pray it hit the cross member and not the pan heh.
Old Jun 22, 2003 | 11:11 AM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
I have a vac ref regulator which (@ idle) knocks the pressure below 30 psi. I think the reason I don't have pulse width problems @ idle, is because I idle @ 850 rpm. If I had a stock cam and tried to idle my setup @ 550 rpm, I think problems would occur.
Old Jun 22, 2003 | 12:51 PM
SlowMaro's Avatar
whats a good AFPR to get, and does it have a guage on it or do i have to go buy a 80 dollar fuel pressure guage.
part #?
i wanna set mine at 22 or so, i think stock is like 10-12.....
im just trying to get everything figured out to give the new heads the fuel flow it needs
Old Jun 22, 2003 | 12:59 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
I'm not sure of part numbers, but mine is a gm model which was originally off a BBC boat motor.
Old Jun 23, 2003 | 04:13 PM
Engine: LO3;383tpi
you can find the gm part number for the afpr by doing a search, I know it has been posted a few times. Limit your search to the tbi and aftermarket product review boards to narrow your search.
Also, don't pay $80 for a fuel pressure gauge. I bought mine from Auto Zone for $40, advertised for tbi, and works great. It comes with a hose long enough to tape to your windshield as well, so you know if your pressure is dropping when under full load.
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Keiffer76
Sep 9, 2015 08:52 PM
