Question about 91 Camaro RS
Old Jun 22, 2003 | 10:37 AM
Chevy454alldway's Avatar
I'm planning to buy a 1991 Camaro RS 305 TBI, and I'm wondering if ALL 91 maro RS's have Governors or not? I can't get ahold of the dealship til monday. I can remove it with no problem but I can't find anything saying whether or not the Governor will be on my new car. Thanks in advance.
Old Jun 22, 2003 | 01:09 PM
89fastlookinRS's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Yeah it most likely will. 305 TBI's are governed at 108 mph. You can splice in a switch to bypass it momentarily or get an aftermarket chip or custom chip.
Old Jun 22, 2003 | 07:24 PM
25THRSS's Avatar
He's right, but it's 112 mph. Ask me how I know
Old Jun 22, 2003 | 08:48 PM
StangKiller's Avatar
How come mine would go 125+ then???? Maybe I had a faulty computer
Old Jun 22, 2003 | 09:34 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
yeah mine is the same way, although I also have a 90 rs and it doesnt cut off at all, ive had it up to around 130 and never cut off.
Old Jun 23, 2003 | 12:50 PM
jlbolin's Avatar
ive had my 91 at 120.
Old Jun 23, 2003 | 12:57 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
have you had it 120? or has your speedo read 120 or 130?
most speedos are very inacurate at high speeds, the ECU will look at the VSS signal and cut it off at 112.
Old Jun 23, 2003 | 06:27 PM
JPrevost's Avatar
Car: 91 Red Sled
Not all were limited to 112, some set at 108, just depends on the year and options.
Old Jun 23, 2003 | 08:09 PM
I only did it a few times, no need for driving that fast, but my speedo pegged after the 115 mark and going by how far the tach climbed I figured I was going 125-130, I think I remember it going to about 3200 RPM in 5th gear, it turned 1500 @ 60 mph, that's 25 RPM per MPH so 3200/25=128 MPH, this was after a few mods like headers and bumped timing, but I did nothing to the puter.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
