redline and wont go above 80mph??
Old Jun 21, 2003 | 01:32 PM
Dragons91RS's Avatar
Car: 91 Camaro RS
Engine: 305 LO3
Transmission: 700-R4
this after noon I ran aginst a mustang. its the first time Ive raced the car since I got it, and I knew Id loose, but not the way it happened.
we went from a rolling start at about 55mph and we both just floored it. I was about 1 car length behind him when we started and that was how it stayed untill we hit 80mph.
for me that was where it ended. my car redlined, hit 80mph and went no further.
what is wrong with my car? I knew id get beat, but I expected to last past 80mph. I was under the impression the governer was set at 115mph.
could it have some thing to do me having the gas floored.
at this point my best guess is the car didnt down shift for some reason.(tv cabel maybe adjusted wrong??)
and yes my car runs fine only prob's I know of is my egr doesnt work quite right all the time, and my valve seals are a little worn.
can any of ya give me an idea what could be wrong?
Old Jun 21, 2003 | 02:42 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
dont you just love not having a 2-3 shift under WOT? Thats a common problem with the stock 700-R4. The throttle valve gets dirty and the trans wont shift into third under WOT. Nothing more then a minor annoyance. Mine does it as well.
Old Jun 21, 2003 | 08:27 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Ive heard that you can get your transmission flushed and it will keep the throttle valve from sticking. try manually shifting, i dont know if it will help or not but it might.
Old Jun 23, 2003 | 08:19 PM
JokerRS's Avatar
Car: 92RS
Engine: 357
mine does that manually ****ing under wot.
HikoriYami
Sep 21, 2015 07:11 PM
brharris27370
Dec 6, 2003 09:58 AM
vadrad
May 26, 2001 07:01 PM
matty350TPI
Aftermarket Product Review
Nov 19, 2000 06:41 PM
matty350TPI
