miss fire
Old Jun 24, 2003 | 09:11 PM
badxs's Avatar
miss fire
i got a 91 tbi 305, i get a miss at 3000 rpm's. im not sure why, ive changed everything accept the ecm and the pick up coil. not sre if the new fuel pump is weak or what? any ideas? whould be appreciated
Old Jun 24, 2003 | 09:38 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
What kind of fuel pump did you put in? Check fuel pressure if you think it's the pump. Does it do it at idle or under load? Has it only been doing it since you've changed everything, or for a while now?
Old Jun 25, 2003 | 09:54 PM
badxs's Avatar
well i got 10 psi, before and after new pump,i dont quite think its the pump. it will only do it at wide open throttle above exactly 3000 rpms, meybe pick up coil????
Old Jun 26, 2003 | 11:32 AM
Engine: LO3;383tpi
Maybe your timing is too far advanced?? It could be that along with a bad knock sensor/ESC module. It could be your pick up coil as well.
Old Jun 26, 2003 | 08:42 PM
badxs's Avatar
i was thinking timming too,could it possibly be to retarded too,and spark cant keep up with motor???
Old Jun 27, 2003 | 08:22 AM
Engine: LO3;383tpi
yes. I've had mine retarded too much before, and it's actually backfired throught the tbi
Old Jun 29, 2003 | 09:35 PM
badxs's Avatar
well i sot it at 0 and 4 degrees and it still does it.... any other ideas?? im not sure what to do next. i think im going to change dist and ecm for the hell of it and the fp too
Old Jun 29, 2003 | 09:36 PM
badxs's Avatar
set itat 0 and 4 deg
KCG
Jun 24, 2020 04:33 AM
PurelyPMD
May 5, 2016 04:57 PM
L98GTA87
Oct 19, 2015 10:43 PM
BLK87Z
Sep 18, 2015 11:29 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
