O2 Sensor
Old Jul 3, 2003 | 10:42 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
O2 Sensor
Ok..I took a short trip one day and maybe went 100 miles (highway) and used about a half tank of gas. Now.. I'm no rocket scientist, but that just seems to be horrible.. especially for a stock LO3 with some exhaust work done. I'm thinking it's time for the O2 sensor to be checked/most likely replaced. I ran it on a diagnostic program and was getting a ton of readings on it. The mv levels were ranging from about 30 to 1000. I heard they should be in the range of 400-800.
If anyone could help me out, I'd appriciate it.
I'm thinking I should just replace it since it is probably dead, or near it anyway.
Old Jul 4, 2003 | 02:06 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i would change it if you suspect it at all, it is a cheap fix.
Old Jul 4, 2003 | 02:07 AM
camaro89rs355's Avatar
Car: 89 Camaro RS
Engine: 355 TBI
305 just get bad gas milage. I put a 355 In my camaro and it get's better gas Mialage now then when it had a 305 in it
Old Jul 4, 2003 | 02:19 AM
Dewey316's Avatar
Car: 1990 Camaro RS
a lo3 in stock form, in good tune should get 25mpg+ on the hi-way. that is not bad, IMHO.
Old Jul 6, 2003 | 03:14 PM
badxs's Avatar
well your o2 readings were good , but its probably lost a lot of frequecy. on average a new o2 will give you at least 4 mpg.just so you know o2's are almost allways bad if there even only a year or so old. o2 should sweep from 0 to 1000 at 18 to 21 thousand hertz.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
