TBI "bogs" on mid-hard accelleration...
Old Aug 19, 2003 | 10:57 AM
woodysfj40's Avatar
1991 350 Chev TBI installed in a FJ40 Land Cruiser- idles great, "casual" accelleration is great, mash the pedal and it bogs down. Actually, anything beyond a casual accelleration. Back off the pedal, and it accellerates casually...mash again, and it bogs.
Motor installed from a running van in Feb 03, problems just arose in July 03, no problems until that time. Truck is used HARD, generally flops/rolls every trip out, most trail use is 1500rpm tops, but it does see occasional road use between trails.
Ran WinALDL, pulled a code 44, replaced the O2 sensor with a stock Bosch one wire, no change (but the code went away, yes I cut power to reset the 'puter.)
Replace the TBI basegasket, no change.
Air cleaner is new.
Fuel pump is new, external, Master E8153.
Fuel filter is new, low restriction filter before the pump.
Yes, the VSS is installed/working. Stock wiring, just cleaned up. 7477 'puter with a stock chip. Install required relocating the knock sensor, motor has hugger headers.
NO other codes....drove it last night about 10pm (my neighbors love me), WinALDL shows nothing. Did not turn on the DataLogger, but can if someone thinks that info will note something. All sensors appear to be sending information in correctly.
Thanks for any assistance.
Old Aug 19, 2003 | 11:08 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
when you plugged it in, what were you BLMs at? also are there any other mods to the engine?
Old Aug 19, 2003 | 05:50 PM
woodysfj40's Avatar
BLM update.....closed loop...all taken at zero mph (in garage)
650 rpm idle = 106
1500 rpm = 121
2100 rpm = 139
2550 rpm = 136
back to idle, 650 = 104
Motor is 100% stock...nothing internal, nothing external other than the hugger headers. Transmission is a 4-speed stick (granny gear)
TIA...
Old Aug 20, 2003 | 12:12 AM
JPrevost's Avatar
Car: 91 Red Sled
650 rpm idle = 106
1500 rpm = 121
2100 rpm = 139
2550 rpm = 136
TIA...
You need to put engine load so take it out of the garage on a safe road with no cars to test for BLM under load. Then report back. Looks like there is a bad sensor of sorts or your eprom is just way off base. BTW, a 106 BLM is impossible on a stock eprom. 108 is the lower limit, is that a typo?
Old Aug 20, 2003 | 05:33 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Jon beat me too it, i tried to respond last night to ask if you could get it going and give us some BLM data under load, but try not to get into power enrichment. but i couldn't get to the site long enough to respond
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
