305 1 piece flywheel to a 2 piece engine
Old Aug 22, 2003 | 08:07 PM
mpresme333's Avatar
Quick question i have a big swap this week i am swapping my 305 5 spd motor for a 350 engine the 5 spd has a 1 piece rear seal the 350 has a 2 piece seal will the 305 flywheel work with my 350 or do i HAVE TO PURCHASE A 2 PIECE flywheel????i have a napa part number SDF6515 for a standard flywheel. can anyone tell me if this is correct or can i save money and use my 305 flywheel???
Old Aug 22, 2003 | 08:10 PM
mpresme333's Avatar
correction i have a 1 piece 305, swapping it for a 2 piece 350
Old Aug 22, 2003 | 08:28 PM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
if you dont have the flywheel for the 350 your going to have to get one, the 305 1 piece will not work. sorry man thats just how it is, the end of the crank (where the flywheel bolts on) on the 350 is not round right?
Old Aug 22, 2003 | 10:32 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
ive heard people talking of machining them to get the one peice flywheel to fit the two piece crank. Basically the hole in the center has to be enlarged and the bolt holes have to be drilled to acomodate teh larger bolt circle of the two peice crank (located offset from the origional holes, of coarse).
BTW, if the present flywheel has lots of miles on it, youd be better off just replacing it.
Old Aug 23, 2003 | 12:14 AM
mpresme333's Avatar
does anyone no of a cheap place to obtain one from? napas part number is sdf6515 has anyone tried this one...Thanks
jhawkeye
May 25, 2022 06:33 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
dutch930
Sep 11, 2015 06:58 AM
BlackphantomZ28
Aug 31, 2015 10:29 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
