Tbi fuel pump relay question
Old Sep 1, 2003 | 06:41 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Anybody out there know anything about the fuel pump relay's exact function? Does it have more than one posistion, does it control voltage at all, how does the engine act when it starts to go bad, or does it just puke and quit ? My Haynes manual doesn't discuss it at all! and only has a wiring diagram for Tpi. I,m working on an 88 form. Lo3, auto. Also getting a code 54. thanks
Old Sep 1, 2003 | 07:58 PM
armac's Avatar
Car: 83 ta
fuel pump relay is a on off relay. turn key on the ECM grounds the relay to cut the fuel pump on. relay could fail in the on or off position. it is howerver connected through the oil pump switch which could cause the relay to run all the time(key on or off) or not run at all.
Old Sep 3, 2003 | 08:47 AM
357mag's Avatar
Car: 94 C1500
Transmission: NV-4500
Axle/Gears: 3:42 10 bolt 8.5"
Also, the oil pressure sw acts as a fail-safe. If the FP relay is shot, the computer will see oil pressure come up during cranking, then allows the FP to turn on, letting you get to the garage to R n' R the relay.
Old Sep 4, 2003 | 11:05 PM
89IROCZ28's Avatar
Car: 1989 IROC Z28
Engine: 305 TBI (L03)
Transmission: 700R4 w/ Corvette servo
Axle/Gears: 4th Gen, 3.23, posi, PBR
I've read if the fuel pump relay is not working you'll experience a longer starting period b/c you won't have fuel pressure until you crank the engine and oil pressure starts to build.
I also get the impression that the oil pressure switch may also affect the voltage being sent to the fuel pump.
Code 54 (less than 2 volts being seen by the fuel pump)
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
