PROM burning and the VAFPR
Old Sep 17, 2003 | 12:52 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
When my 350 gets here, I'm taking my car to get a new PROM burned while on the dyno by this company. Since it will be a custom chip, is it necessary to have the VAFPR or will simply making the stock FPR adjustable (per tech articles) do the job?
I've read that the VAFPR is simply just a "band-aid" for PROM burning, so why should I purchase a "band-aid" if I'm going in for surgery? (if that analogy works)
I will also be going to "cop car" injectors during this switch.
Old Sep 17, 2003 | 02:07 PM
kevm14's Avatar
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
The simple answer is, try a static pressure first. Be sure to choose a pressure that will support your HP level and RPMs you plan to rev to. Then set the injector constant correctly and tune away. You will know if you need a vAFPR if your idle quality appears to be worse than it should be for your cam duration. Also, if the injectors are running async, your idle emissions could be worse (GM went to smaller injectors on the 454 TBI in the late years due to this reason).
Other than that, there is no reason to run a vAFPR when doing a full custom tune.
HTH
Old Sep 17, 2003 | 03:06 PM
Ronny's Avatar
i would suggest vafpr is instead of tuning ecm. i added the vafpr to a modified engine with stock puter and later removed it when i went to programable ecm and started burning chips. along with that in went the larger injectors from 454 at 90 lbs. BTW i have one vafpr used (one month)and modified to fit and another new in box. new i paid $50 for each. send me email if interested.
Old Sep 18, 2003 | 12:25 AM
JPrevost's Avatar
Car: 91 Red Sled
I've tried both and won't be using a VacAFPR from here on out, unless dual TBI , kind of hard lowering the pulse width on 4 injectors for idle at 25psi of pressure.
What kind of 350 are we talking about, 200hp or 350?
Old Sep 18, 2003 | 09:30 AM
Ronny's Avatar
my first use was on dual throttlebody. 350 cid crossfire/vette. what application has 4 TB's?
Old Sep 18, 2003 | 09:31 AM
Ronny's Avatar
or should i have said 4 TB's with 4 injectors?
Old Sep 18, 2003 | 10:07 AM
Car: 91 RS
Engine: 350 TBI
300 HP
So the consensus is that I should just make mine adjustable, then give the car to the chip buring guys?
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
dusterbd
Sep 29, 2015 08:40 AM
