The right winaldl cable?
Old Sep 22, 2003 | 11:04 PM
25THRSS's Avatar
Is this a good cable to get guys? How well will it work with tbi?
http://cgi.ebay.com/ebaymotors/ws/e...item=2434000839
Old Sep 23, 2003 | 09:51 AM
614Streets's Avatar
Dont know if this is any consulation but I made one last year for about 17 bucks. Everything is available at radio shack.
Old Sep 23, 2003 | 10:12 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
mine cost me about $8 all radio shack parts. if you can solder at all, you can make your own cable easily.
Old Sep 23, 2003 | 12:27 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
I think earlier he said he'd rather buy one???
I don't know if its a good cable however.
Old Sep 23, 2003 | 01:07 PM
25THRSS's Avatar
I already did the radio shack thing and in order for me to make it correctly I'de need a different soldering gun, as the one I have is way too big for the application. Besides I can't solder worth a crap anways and after 5 tries to make the cable and failing I think I'll just buy one. So is this cable good for our cars or not?
Old Sep 23, 2003 | 01:36 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
thats total overkill for your application if your only going to use it for the tbi car. If you dont mind spending the money it should work for what you want. What kind of soldering iron do you have? Investing in a $15 soldering pen is a good investment. I always keep one on hand in my tool box. If you build the hardware into a project case it can be easier to solder because the components are more spaced out. I sold my last winaldl cable for 10 dollars or so after i built the interface into my dashboard. Ive seen others sell the basic cable for the same price. If you pm some people or put out an ad in the classifieds, im sure you could find a reputible member willing to build one for less then what he is charging. Its a real nice piece, but its a bit costly for what you want. If you dont mind paying the cost, it should work at least with the software listed and i would assume winaldl as well, but im not %100 sure.
Old Sep 24, 2003 | 08:12 AM
Sonny01's Avatar
Hi,
The colored wires do not have an connector on it...you have to stick the probes into the socket on your car. A bit hard to drive that way I think.
Sonny
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
