Detonation
Detonation
Hooked up winaldl to my 89 tbi and am getting incredible amounts of knock.. around 18 at idle all the way up to 170 when driving.. I tried bumping the fuel pressure up but it still seems to be no help.my gauge reads at about 16 psi.. could this be false knock.. and can an engine even run smoothly with that kind of knock??
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
What is your base timing set at and what grade fuel do you use. Use a higher octane fuel, decrease your base timing and re-scan and see what you get.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
are the knock counts across the board? or in a few specific cells?
yeah, back your timing off a hair, i found that when i tried to go up to 8* even on 92 octane, i got tons of knock, but can run 6* all day on 87 <shrugs>
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Dewy's right, 6* is pretty standard. My engine didnt knock with 8* when it was stock on 92 octane, but they're all different.
ON MY WAY TO GET A NEW TIMING LIGHT MY ENGINE DECIDED TO DIE! still has oil pressure though, but some real loud nasty banging going on inside.. also with clouds of smoke behind car.. GUESS IT WASNT FALSE KNOCK, TIMING WAS AT 4 BTDC AND ON 93 OCTANE.. The engine mods were lt1 cam, 3 inch exhaust edlebrock intake, bored out tbi, underdrive pulleys, Open elemnt, but now that i think of it i switched the stock aircleaner housing back on for inspection before i took off tongiht...?needless to say im pissed off very greatly..
MikeH
Nov 16, 2001 11:57 PM
