Newbie has questions
Old Sep 25, 2003 | 08:35 PM
lilxtra's Avatar
I'm working on a '95 Chevy truck that originally had a 350 engine in it but the owner had a built 468 ci big block put in but they are using the stock throttle body & computer,I'm getting a piggyback unit from pcmsforless but my question is about swapping on a big block(supposedly)throttle body but the IAC & TPS sensors have different conectors & won't interchange on the throttle body's.I have rewired each according to the wire colors & also tried each by matching the A,B,C,D wires to each other even though the wire colors don't match & the truck runs rough & worse than it did w/h the 350 tbi on it.Any suggestions on which wiring is correct? that way I will know if the IAC,TPS or both are bad on this big block unit.Thanks for any info.Scott
Old Sep 30, 2003 | 10:17 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
ttt
Old Oct 1, 2003 | 12:12 AM
lykan's Avatar
The 454 TBI will work with that computer, but you will have to have a new chip burnt. You have to chewck the intake bores on your current setup, and make sure they are 2" to match the 454 TBI.
Do a search for 454 tbi, and you will find a post where someone had some difficulty, and ended up figuring out how to wire the 454 TBI correctly.
actually..if you have a big block in there now, and you run the 454 injectors too, you might not have to burn a custom prom. If you have a 350, you have to reprogram the ECM for the bigger injectors, because it will be way rich.
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
R3500
Aug 24, 2015 09:05 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
