454tbi and intake
Car: 1992 Camaro RS
Engine: 383 w/Holley Stealth Ram
Transmission: Pro-built 700R4
454tbi and intake
what intake can i use with the 454tbi that will fit the early style heads?? i'd like to stay witht the TBI intake but will go with a 4bbl intake if i have to. i have to watch hood clearence right now so that is a factor. please help thanks
nick
nick
Holley 300-66 manifold has the 2 inch bores. Good luck getting everything to work though. You'll have to find an EGR that actually fits and get a spacer to clear it. My advice for the EGR on the 300-66 is to just block it off. You will also have to re-route your vacuum lines and heating lines. I had to shave down my distributor to get it to fit in my GMPP manifold, which had the same size distributor hole as the 300-66 I gave to my friend. He is using it on his ZZ4 motor, with the holley 670cfm TBI base and he loves it.
I plan on getting my Vortec TBI manifold bored out so I can bolt on a 454 TBI, but for now I'm going to use my holley neck down gasket.
Car: 1992 Camaro RS
sorry i'd also like a single plane intake. lose HP and Torque with a dual. Nick i will not be running a EGR vavle either.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I own the GMPP Vortec TBI manifold and it has the stock 1 1/16" bores
I thought it had 2" bores also, till I got it. Hence why my friend has the holley TBI base, I gave it to him along with the 300-66 (didn't need that anymore) for helping me with the swap.
No shop around Tampa FL would bore my manifold out for me. I could've sent it away, but I did not want to wait another two weeks to do the engine swap. I had asked for the entire weekend off to do the swap.
I thought it had 2" bores also, till I got it. Hence why my friend has the holley TBI base, I gave it to him along with the 300-66 (didn't need that anymore) for helping me with the swap.No shop around Tampa FL would bore my manifold out for me. I could've sent it away, but I did not want to wait another two weeks to do the engine swap. I had asked for the entire weekend off to do the swap.
Car: 1992 Camaro RS
for the TBI it looks that way. thats what i found by using DeskTop Dyno. 391 HP 440 torque single plane, 375 HP 436 torque dual plane. that what my new motor specs will drop with the dual to single.
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
